L293, Motors and multiplexing... help!
Discussion in 'General Electronics Chat' started by madaeon, Sep 7, 2016.
  1. madaeon
    Sep 7, 2016
    I have a project where I need to drive 8 "tiles" each one with 6 motors (12v DC) in both directions.
    The motors will stay off most of the time, with bursts of 1second in one direction or another, one at a time, arduino controlled.
    I am looking for the most efficient, compact and economic way to drive them.
    At the moment I use the L293D IC, one can drive 2 motors, but I still end up with 24 ICs, they take up space, and cost.
    I can make h-bridges with just transistors and resistors, like the BD139 and BD140. Cost less than L293d
    But for each motor I would need 4 transistors, so each tile (6 motors) would be 24 transistors + resistors, quite many, wieght will also add up too much.
    Is it possible to use some kind of "multiplexing" of the output of the L293?
    If so I could use just a few of them and use some multiplexers to deliver the output to all the motors.
    Thank you very much!
  2. wayneh
    Sep 9, 2010
    12,389
    3,245
    Just thinking out loud. Could you make it work with a single H-bridge to change polarity, followed by MOSFET arrays to distribute the power? A MOSFET conducts in either direction when the gate is high. If you use ones without body diodes, it won't conduct with the gate held low.
