On the ON indicator light lamp sockets for a lot of the equipment I am working on. They are rated at about 6.3v since they are connected to the heater voltages. I want to replace these lamps with LEDs. I calculated the resistor that I would need to reduce the voltage to about 3.5v for the led bulb was about 150 ohms. However after I connected the resistor and inserted the led in to socket I am reading 5v across the led terminals. I don't want to burn the led out, is there something that I missed?
