The assignment of voltages and currents is completely arbitrary -- you don't even have to abide by the passive sign convention.
Consider the following choices of assignments, all of which were made via flipping a coin:
Let's write KVL equations for the outer loop, the leftmost loop, and the top loop on the right (in that order), going clockwise starting from the lower left corner of each loop and summing up the voltage gains:
Loop #1: - V0 + V3 - V4 = 0
Loop #2: - V0 - V1 - V2 = 0
Loop #3: + V1 + V3 + Vab = 0
We could write several more (four, I think) loop equations, but they would all be linear combinations of these three.
Using Ohm's Law, we can relate the voltages to the currents as follows:
V1 = I1·R1
V2 = - I2·R2
V3 = I3·R3
V4 = - I4·R4
Applying KCL at the upper three nodes, summing the current into the node:
Top Node: - I0 - I1 + I3 = 0
Node A: I1 + I2 = 0
Node B: - I3 + I4 = 0
We could write another node equation for the bottom node, but it would be a linear combination of these three.
Now it is a matter of plug and chug:
Vab = - V1 - V3
Vab = - I1·R1 - I3·R3
V0 = -18 V
I2 = - I1
I4 = I3
From Loop #1
- V0 + V3 - V4 = 0
- V0 + I3·R3 - I4·R4 = 0
- V0 + I3·R3 + I3·R4 = 0
I3 = V0/(R3 + R4)
From Loop #2:
- V0 - V1 - V2 = 0
- V0 - I1·R1 + I2·R2
- V0 - I1·R1 - I1·R2
I1 = - V0/(R1+R2)
Therefore
Vab = - [- V0/(R1+R2)]·R1 - [V0/(R3 + R4)]·R3
Vab = V0·{[R1/(R1+R2)] - [R3/(R3 + R4)]}
Substituting in the values for this particular circuit:
Vab = (-18 V)·{[(2 kΩ)/(2 kΩ + 6kΩ)] - [9 kΩ/(9 kΩ + 3 kΩ)]}
Vab = (-18 V)·{[2 kΩ/8 kΩ] - [9 kΩ/12 kΩ]}
Vab = (-18 V)·{(1/4) - (3/4)}
Vab = (-18 V)·(-1/2)
Vab = 9 V
Note that your original answer of Vab = -9V is wrong. You calculated Vba. Vab, by convention, is Va - Vb.
V1 = I1·R1
V2 = - I2·R2
V3 = I3·R3
V4 = - I4·R4
Node A: I1 + I2 = 0
Vab = - V1 - V3
V0 = -18 V
I2 = - I1
I4 = I3
From Loop #1
- V0 + V3 - V4 = 0
I3 = V0/(R3 + R4)
From Loop #2:
- V0 - V1 - V2 = 0
I1 = - V0/(R1+R2)
Therefore
Vab = 9 V
