KVL: Mesh Current Method
Discussion in 'Homework Help' started by Steve1992, Mar 10, 2010.
  1. Steve1992
    Thread Starter Senior Member
    Apr 7, 2006
    100
    Im using the Mesh Current Method to find the voltage across R2 (5k). I dont know how to write the equation for Loop 3.
    I tried removing Loop 3 from the circuit then calculating the currents for loop 1 and loop 2, then putting back loop 3 (6 mA) back into the circuit - that didnt work.
  2. MilK
    Member
    Mar 1, 2008
    25
    The current 6mA flows in R5 path, hence you can find the voltage across R5.
    The voltage across R5 = voltage across R2 since the two are parallel.
  3. The Electrician
    Oct 9, 2007
    2,301
    339
    The voltage across R5 does not equal the voltage across R2.
    The equation for the third loop is: I3 = -.006, assuming you take all the mesh currents to be clockwise.
  4. Steve1992
    Apr 7, 2006
    100
    I converted the current source (6 mA) to its Thevenin equivalent which simplified the equations:)
