If you see my other thread which i have posted in the general electronics section titled "applying KVL to the transistor amplifier circuit", you will find out what is the problem.i dont find anything wrong in it.
do u think there is anything wrong?
Here is a sketch of the transistor model that I would use to write the KVL equations for the CE stage in you provided. It should be suitable for DC analysis.[/URL][/IMG]
This diagram shows transistor amplifier circuit.The thing which is bothering me is the fact that they have used the batteries instead of "current dependent current sources",and applied the method which i have used above to deduce the result.hgmjr said that it cannot happen.That is the problem.
Note:I have not mentioned input and output terminals,the input is at extreme left and the output is at extreme right.
Where is the transistor????!!!!....Here is a sketch of the transistor model that I would use to write the KVL equations for the CE stage in you provided. It should be suitable for DC analysis.
hgmjr
