KS1080 Hi tech C library
Discussion in 'Embedded Systems and Microcontrollers' started by wannaBinventor, Dec 13, 2010.
  1. wannaBinventor
    Apr 8, 2010
    179
    I'm learning C right now and I think I'll end up using Hi-Tech C for the 16F (feel free to recommend a better compiler). Learning C is coming along okay. I think once I get comfortable with some of the "hello world" type stuff, I'd like to get to work with a KS0108 based graphic LCD. Does anyone know where I can find a library LCD in C for the 16F? I'd also be open to a working program for a 16F PIC in assembly code if someone knows where I can find that.
    Thanks fellas.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Microchip released its XC compiler recently and is based on the Hi-Tech compiler. I would recommend that since it is quickly becoming the norm.
    You would be using the XC8 flavor - for 8-bit PICs.
    Edit: I just realized I got suckered into responding to a necropost.... :(
