Knowledgeable about encoders?
Discussion in 'General Electronics Chat' started by GenJacks, Jun 25, 2016.
  1. GenJacks
    May 15, 2016
    6
    Our only elevator in the company is not working since May. This has been very difficult for others and my part as well because my office is located on the 3rd floor. The technicians in charge told me that they have no stocks of “rotary encoders” to replace the defective one and said it would take 3 more months to order for replacement. So, I volunteered to personally look for this equipment so that they can fix it ASAP. I would like to ask if there is any company or supplier than can help me. Any suggestions? TIA
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Umm... Seriously? You're not thinking of doing the work yourself, are you?
    To help locate the item having the manufacturer and the exact part number(s) is essential.
  3. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    If this is a typical quadrature rotary encoder there are several mauf. where a sub can be obtained from.
    You require to know output detail, RS485 differential? single ended open collector, push pull output.
    Also is it shaft driven type or through hole.
    As reported, the original model & make is needed for any more recommendation.
    Max.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If you do this work yourself, you should understand the world of economic hurt you will be in if someone is killed or injured.
  5. GopherT
    Nov 23, 2012
    6,309
    4,029
    Wait for him...
    @Glenn Holland should be here momentarily.
  6. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    I have worked on freight elevators or though technically here you have to have a elevator electrician license.
    However I have installed and replaced hundreds of encoders of different makes and stripes, and they are relatively easy devices once you get into them.
    AFAIK the only personnel elevators that use encoders are AC motor/VFD closed loop types.
    Max.
  7. GenJacks
    May 15, 2016
    6
    Honestly speaking, I do not know much about rotary encoders. All I want is to get a replacement, so technicians can start fixing our elevator. I am going to ask them on what specific details do we need whether "AC motor/VFD closed loop types or whatsoever". BTW, someone suggested to try "Dynapar". Sorry I do not have any idea about this company or supplier, but if you are familiar and you have tried it before, please let me know ASAP. Thanks everyone for your comments, I appreciate it very much. :)
  8. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    Can you at least get a part No. from the original encoder?
    Max.
  9. MrSoftware
    Oct 29, 2013
    545
    133
  10. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
