Hello All,
First time posting here ater few days of trying to figure out what happened. If you can help, it will be very appreciated.
I just completed painting my condo unit, bought new furniture and made my apartment a "couiples" apartment since i will be getting married soon.
My issue here is that i was changing the electrical outlets and switches as i finish painting every room . [I was changing the outlets/switch plates to match the colour to go with the room), Evrything was going fine until i had 1 more room to complete and that is the kitchen. I tried 1 of the 2 outlets (i did not touch the refridgerator and stove outlets as it is not visible),in the kitchen and i did the same process as any other outlets that was done prior with other rooms. The problem is that i always test the outlet to make sure everything is ok, so, i turned on the fuse in the electrical panel and "BANG", fuse down. I de-asembled the outlet and let the wires loose and turned on the fuse again. Evereything is back to normal. No problem what so ever. So in case i did not do a good job in hooking the plug correctly, i looked at the similar plug to "copy" the wiring from. I did exactly that, and retested. The 2 fuses shut down this time, it also shut down the kitchen lights and the living/dining room and stove. It was odd that the fuse that would go off would be the fuse for the plug alone. So, i de-assembled the plug again and turned both fuse on. The lights went on, but very dim, what's odd is that every time i turn something on, it lowers the electricity somewhere else.
For example:
I turn on the kitchen lights alone, it is strong. If i ALSO plugged a fan in the living room, the kitchen lights dim a little and the fan is not at its highest form. The stove i can't turn on, not enought electricity to turn it on. The more i plug stuff, the weaker they get.
After i did some research, i found out that the original kitchen outlet, does not have both plugs connected using same circuit. However, when i changed the outlet (they looked identical), both plugs were connected by a metal to provide same current for said circuit. Therefore, when i tested the plug, short was created. 2 circuits combined as 1 which affected 2 seperate fuses.
Does anyone know how to reverse the damage? Or, a electrician must come to fix?
If anyone have an answer, please help
Termi
For example:
Termi
