Hello all, I am in need of some guidance with my current project. I am building a play kitchen for my two girls as a Christmas gift, but I am wanting to make it unlike any other. My plan is to make the "appliances" as realistic as possible, with illuminating burners, oven element, microwave and fridge lights, etc.
The problem I have run into is how to make the "burners" illuminate on the stove top. The stove is designed to be a flat surface range, with 12V LED flex tube lights nestled into burner drip trays mounted beneath a sheet of plastic to mimic the glow of the stove top burners. However, I have not been able to find a solution for how to achieve this.
From the several forums I have read it seems that potentiometers tend to give off heat, significantly in some cases, and I may not be able to turn the lights off completely. So my question to this community is how do I go about making a play stove with "burners" that can be shut off completely, and gradually brightened WITH knobs, like a normal stove, but without requiring significant voltage and current, or other potentially hazardous side effects?
Any and all help is greatly appreciated, and I will follow up with a completed project post once this baby is done! The frame is built but I want to have the electrical completely figured out before I go much further with this. Thanks in advance!
