Hi guys. Im new to forums as you can see and im struggling a little breaking down the circuit correctly. I have performed calculations and simulated it and found the exact values using Gauss_Jordans rule with a spreadsheet i made up.
Here is the simulations with both the actual circuit with the shortened down version. I have simplified from the right to reach the point where i get a value of 362 ohms with a 10v supply
https://www.dropbox.com/s/lpb574val39pa0g/Screenshot%202015-01-24%2015.14.49.png?dl=
If it is correct, what would be my next step? Itotal = -i1 --i2 - i3 - i4?
Your help will be appreciated.
Alex
Alex
