Kirchoff law problem
Discussion in 'Homework Help' started by logearav, Dec 28, 2012.
  1. logearav
    Aug 19, 2011
    248
    Revered Members,
    Please go through my attachment. I have been asked to find the magnitude and direction of current through the 10 ohm resistor. The answer that is given in the book is 1/23 Ampere from A to B.
    But i solved as given in the attachment but i got the answer as 5/37 Ampere which is I3...the current which I assumed to pass through 10 ohm resistor. Since Please help me where i went wrong.
      File size:
      238.4 KB
      35
  2. mrmount
    Dec 5, 2007
    59
    7
    I got the same answer too!
    logearav likes this.
  3. MKCheruvu
    Member
    Nov 20, 2012
    30
    6
    Solving this problem by super position theorem :
    Ir10 due to 8v source = 16/74 and
    Ir10 due to -2Vsource = -6/74
    Net Ir10 Current = 10/74 =5/37
    The answer is same
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Yet another approach:
    Remove the 10Ω resistor and find the Thevenin equivalent between A and B for the rest of the circuit.
    Rth = 12Ω||8Ω = 96Ω^2 / 20Ω = 4.8Ω
    Vth = -2V + 10V(8Ω/20Ω) = +2V
    Now put the 10Ω resistor back in and you have:
    I = 2V/(10Ω + 4.8Ω) = (1/7.4)A = (5/37)A
    The Point: If you can work the problem several different ways and all produce the same answer, then there is good reason to believe that your answer is correct and the book is wrong (unless every method you used had some flaw in common -- so be sure to be on the lookout for that).
    You come up with an answer of (5/37)A. So check the validity of the answer starting from the answer itself:
    V_B = 0V (I'm defining B to be ground). This means that
    V_A = (50/37)V
    This makes the current toward A from the left
    I_12 = [8V - (50/37)V]/12Ω = [246/(37*12)]A =(41/74) A
    Likewise, the current toward A from the right:
    I_8 = [-2V - (50/37)V]/8Ω = [-124/(37*8)]A =(-31/74) A
    Now we can see if KCL is truly satisfied at Node B:
    I_12 + I_8 =? (5/37)A
    (41/74)A - (31/74)A = (10/74)A = (5/37)A
    The Point: In a surprisingly large number of problems, both in school and in the real world, it is possible to verify the correctness of your answer from the answer itself. Get in the habit of doing so. You grades will probably take a significant turn for the better and you will be less likely to kill someone down the road because of an undetected error.
  5. sleet1986
    Dec 29, 2012
    your answer is right
  6. JoeJester
    Apr 26, 2005
    3,402
    1,221
    I looked at it two ways ... Millman's and Superposition.
    5/37ths is correct.
  7. logearav
    Aug 19, 2011
    248
    Thanks a lot everyone for your painstaking efforts to help me.
