Kirchhoff's Laws... pls help
Discussion in 'Homework Help' started by paulmc, Aug 13, 2006.
  1. paulmc
    Aug 1, 2006
    9
    I am having difficulty with these types of problems. if anyone could help me with this question. thank you.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings paulmc,
    I have converted your attachment to .PDF format for those members who would prefer this format.
    You will find some very good information on Kirchoff's voltage and current law in the AAC Tutorial section. (see link below)
    http://www.allaboutcircuits.com/vol_1/chpt_6/index.html
    hgmjr
  3. zarshis
    Aug 21, 2006
    Use junction rule at D
  4. gaya3eeee
    Aug 18, 2006
    7
    KCL:
    hint: sum of currents flowing inside the node=sum of currents flowing outside the node.
    KVL:
    hint: if you want to find the terminal voltage, then it should be equal to sum or may be the diff of voltage drop in the resistors.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Harry,
    The pdf doesn't seem to open, it claims to have found an error when opening the file: This file can't be found :confused:
    I am using Acrobat Reader 6 here so it may just be a version compatibility issue. Can you confirm that it opens fine at your end?
    Dave
  6. JoeJester
    Apr 26, 2005
    3,397
    1,214
    Dave,
    The pdf didn't open in the browser, but if you did a save as ... it opened just fine.
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Thanks Joe.
    That did work when using Acorbat Reader 6, however it does open in the browser if you use Acrobat Reader 7 (using Opera 9 with the appropriate Adobe plugins).
    Thanks.
    Dave
