Kirchhoff analysis - Help needed
Discussion in 'Homework Help' started by jboavida, Nov 22, 2008.
  1. jboavida
    Jul 10, 2008
    23
    Hi All,
    Please take a look to the attached circuit.
    By the KVL (please correct me if i'm wrong):
    Mesh I5
    I3R3 + I4R4 + I5R5 = 0
    Mesh I4
    I8R8 + I2R2 + I3R3 = 30
    Mesh I3
    I7R7 + I5R5 +I6R6 = -10
    I dont know how to do the equation on mesh I1 and I2 because of the current source.
    I think I have all the meshe's.
    Thanks in advance for your help.
    Joaquim
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You have neglected to take into account the currents flowing in the loops whose current also flows through resistance that are common to a given loop.
    I will provide you with the expression for mesh I5 to give you a starting point on how to form the remaining expressions.
    mesh I5:
    (I_{5}-I_{4})*R_{3}\ +\ I_{5}*R_{4}\ +\ (I_{5}\ +\ I_{3})*R_{5}
    hgmjr
  3. jboavida
    Jul 10, 2008
    23
    Thanks hgmjr for the awnser.
    I understood what you mean. The influence of the other currents of equal or opposite signal.
    But about my primary question . How the solve the mesh with current source? How do I treat the current source?
  4. blazedaces
    Jul 24, 2008
    130
    The current loops containing a current source are the easiest of all... they are equal to the current source.
    Think about this for a second. The current in a given wire between two nodes must be a constant value, correct? So if I2 - I1 pass through a given wire between two nodes AND a 10 amp current source is in between two nodes... those two values MUST be equal...
    For example, in your circuit, 10 = I2 - I1
    Now, do KVL for all the loops NOT containing current sources...
    But, also make a loop going around both I1 and I2. For example:
    4*I1+20+14*I2-14*I4+9*I2-9*I3=0
    Does that make sense?
    -blazed
  5. jboavida
    Jul 10, 2008
    23
    Thanks Blased
    So, if I undestand correctly, the equations for I1 and I2 are 2
    I1-I2=10
    and the supermesh equation:
    correct?
    Along with this I have the other equations for mesh's I3 I4 and I5
    Did I get it?
  6. blazedaces
    Jul 24, 2008
    130
    No problem. Everything is correct except the following:
    If you take another look at your diagram you'll notice that 10 amps is going in the same direction as I2, but in the opposite direction as I1, so 10 = (-I1) + I2 = I2 - I1
    Besides that, you've got it. :)
    -blazed (assuming you've corrected your equations using hgmjr's advice...)
