Kicad schematic update
Discussion in 'General Electronics Chat' started by LaurenceR, Jul 6, 2014.
  1. LaurenceR
    Feb 7, 2013
    97
    I am using Kicad to build a printed circuit board. I created the schematic, associated the correct modules and associated it with the pcb board. After laying out the connections I wanted to change two connections to my op amp module. I went back and changed the schematic and tried to re-associate it to the pcb board. No changes in the connection showed up. The pcb board won't let me revers the connections (+ and - terminals). I must be missing something. Any help would be appreciated.
    Thanks,
    Larry
  2. LaurenceR
    Feb 7, 2013
    97
    My apology.
    I'll look for an appropriate site.
  3. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  4. djsfantasi
    Apr 11, 2010
    2,906
    879
    Give it a chance. Your two posts were but an hour apart. Perhaps no one with Kicad experience logged in during that time. It can take up to 24 hours some days to get a reply.
  5. LaurenceR
    Feb 7, 2013
    97
    Your right. I jumped the gun a bit. I didn't notice the "off topic" heading when I first posted it and thought that was some kind of response. Will also check out the other suggested site.
    Thank you both.
  6. ErnieM
    Apr 24, 2011
    7,439
    1,627
    With Kicad you have to recreate the Netlist in schematic editor for the PCB layout editor to see them.
    The Netlist is how one editor talks to the other.
  7. LaurenceR
    Feb 7, 2013
    97
    I'm not changing any of the components, just two connections. Then I save the whole project before going to pcbnew. the changes on the schematic don't show up on the pc board.
    Thanks,
  8. ErnieM
    Apr 24, 2011
    7,439
    1,627
    Again, if you want ANY change in the schematic, no matter how minor you feel it is, to appear in the PCB you first have to re-create the netlist, then load it again in PCB editor.
    Choose the load options carefully in the PCB editor. Save your work just before you do this in case the load goes bad.
  9. LaurenceR
    Feb 7, 2013
    97
    I believe I found the answer on the web. Apparently saving the changes to the schematic doesn't mean they will transfer to the pcb. When you read the net list from pcbnew you have to check off the "delete bad tracks", "change modules" and "remove extra foot prints" in order to see the changes. It worked great. Here is the web site if anyone is interested.
    http://store.curiousinventor.com/guides/kicad/pcb_layout/change_part
    Thank you all for your help.
  10. ErnieM
    Apr 24, 2011
    7,439
    1,627
    Apparently telling you such twice did not help you in your quest.
