KiCad help - micro via
Discussion in 'General Electronics Chat' started by bug13, Jul 11, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    I am learning KiCad today, and the help menu say micro via is "Ctrl + V", but when I pressed "Ctrl + V", I got nothing.
    So how do I place a micro via?
  2. bug13
    Feb 13, 2012
    1,213
    38
    I got it, I need to enable the micro via option :)
  3. bug13
    Feb 13, 2012
    1,213
    38
    Oh no, I still can't do micro via after I enable the option. any thought??
  4. ErnieM
    Apr 24, 2011
    7,436
    1,626
    As a Kicad user and supporter I took it as a point of honor to figure this out, even though I have not nor intent to use a micro-via in my work.
    A micro via or micro-via or microvia (I've seen it all ways) is a very small (LDO) (.1mm/.004inch typical) connection is a multilayer board. A hole is cut using a laser or (other very controllable process) between an outer layer and the layer directly below it. The prepreg board thickness needs to be of the order of the micro-via diameter so the technique is limited to multilayer boards.
    With this limitation enabling micro-vias in Kicad takes two steps. From the menu click:
    Design Rules | Design Rules: Global Design Rules tab click "Allow micro vias."
    Design Rules | Layer Setup: increase Copper Layers to greater then 2.
    Once you do these steps when drawing a trace you can press V to place a via, and CTRT-V to place a micro-via.
    (This took me a while as I am breaking in a new computer and had to download Kicad into this machine. Sorry for the delay but I kept your post up till I got this.)
  5. bug13
    Feb 13, 2012
    1,213
    38
    Hi ErnieM
    Thank you for taking the time to find these out for me, it looks like I am poking on something I have no idea of. (I am justing assuming micro via is just a via but smaller, and I can use it just like a normal via)
    I was doing it on a simply 2 layers board and of course it doesn't work.
    KiCad is great btw, after trying Eagle, Design Spark and Altium (this is great too but too expensive).
