Hi all,
I'm a brand new Kicad user and have some basic questions after designing my first board:
1. My PCB is two layer yet all of my components are through-hole. How do you solder an IC socket, for instance, if some of the tracks leading to the pins are on the top and some are on the bottom?
2. I have put all the power flags in correctly on my schematic and get no errors when I run the checker but the finished PCB has no obvious place to connect Vcc and GND. Is Kicad expecting me to make a "ground plane" and a "Vcc plane"? If so, is one plane covering one side of the board, the other plane covering the opposite side?
3. There are a number of places where the track must go from the front of the board to the back of the board. I believe these are called "vias"? How do I actually connect a via? Or does this get done by the board manufacturer?
Many thanks in advance!
Kevin
Kevin
