keypad interfacing
Discussion in 'The Projects Forum' started by ms_kishor4u, Oct 20, 2008.
  1. ms_kishor4u
    Oct 17, 2008
    5
    hi to all;
    is there any method for the key pad scanning using interrupts. how to do keyscan in the interrupt. pls give me some ideas...
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Have a look at this short explanation of keypad scanning. In the article there is brief mention of the use of a 3-input NAND that can be used to produce what is sometimes refered to as an "any key pressed" signal. Feeding the output of the NAND to an external interrupt pin on the microcontroller will provide you with a means of detecting that a key has been pressed.
    There are a couple of ICs made by National Semiconductor that can be used to interface to a row/column organized keypad. I believe the part numbers are 74C922 and 74C923. The main difference between the two ICs is the number of switches they support.
    hgmjr
