Keypad button labels
Discussion in 'General Electronics Chat' started by Druzyek, Aug 25, 2013.
  1. Druzyek
    May 19, 2013
    21
    I have a button matrix made from 6x6mm push buttons like these:
    http://www2.mouser.com/ProductDetail/Schurter/13019317/?qs=sGAEpiMZZMuwaeeX4K1QqEaCG2iXYHLJ
    I would like to glue labels directly to the buttons to make a sort of keyboard. What would be the best way to make hard plastic labels at home? Something like the plastic used to make credit cards would be ideal. I thought about using lamination but this probably isn't very durable. Is there anything I can make with common materials?
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    You can use transparency material with the label printed on the bottom side, so it is protected from wear. But with those tiny buttons, I doubt that any kind of label will stay on.
  3. Druzyek
    May 19, 2013
    21
    What do you mean transparency material? Do you mean putting plastic directly into a printer? I was hoping to make the label 10x10mm or so. I think something like credit card material could be glued on if the wear wasn't too rough.
  4. ErnieM
    Apr 24, 2011
    7,433
    1,623
    These are some switches I use. You can get them from Sparkfun or from Ebay if you hunt around. I like them a bit more then plain tactile switches as they have a large (and colored!) button face.
    [​IMG][​IMG]
    Note these have a nice lip at the bottom. When mounted on a board behind the front panel this lip will keep the button from popping out of your unit.
    You could make something similar for your tactile buttons, and add whatever marking you wish.
  5. Druzyek
    May 19, 2013
    21
    Thanks for the suggestion. The matrix is already soldered so I don't know if I could find some that fit. The big problem is putting the symbols I want on the buttons.
  6. tracecom
    Apr 16, 2010
    3,878
    1,396
    At 10mm square, I don't know how you will keep the labels on the tiny buttons. How far apart are the switches?
  7. MrChips
    Oct 2, 2009
    12,622
    3,451
    You can try Brother P-Touch label makers. You will have to cover the label to prevent it from wearing off.
  8. Druzyek
    May 19, 2013
    21
    A few mm apart. 10x10 would fit. Hmm, I don't understand why they wouldn't stick. Doesn't super glue work fairly well for plastic to plastic? I was thinking thin plastic like a credit card. Anything should work as long as it isn't very flexible.
    I think I know the ones you mean but aren't those labels fairly flexible?
    Right. How would I do that?
  9. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    +1 !
    10mm sq labels attached to buttons <5mm ??
    Max.
  10. MrChips
    Oct 2, 2009
    12,622
    3,451
    Use Letraset for the lettering then cover it with clear book cover protector.
