keyounce mask and oscillator
Discussion in 'The Projects Forum' started by blueorange_888@yahoo.com, May 3, 2012.
  1. blueorange_888@yahoo.com
    Apr 30, 2012
    what is a key bounce mask and oscillator in MM74C923 encoder and what is their function? can anyone please help me with this
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
    Key bounce is a term used to describe the fact that when you use a mechanical switch, the switch contacts will sometimes bounce against each other before they settle in the "on" position. This can make it look like the switch was hit multiple times, very quickly. The debounce circuit will eliminate these fast multiple open/close switch cycles so that each switch activation results in only one off-on cycle.
    The oscillator is a circuit that drives the sequential logic to scan through the switch array, looking for switch closures.
  3. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    At pin 7 of the MM74C923 there is a "Keybounce mask" capacitor.
    The value is about 10 times that if the oscillator capacitor.
    See the attached datasheet for more info.
    Bertus
    PS Don't use your email-adresses as user name.
