Keyboard problem
Danys
Joined Jun 6, 2013
5
I have become owner of used laptop HP 2510p. Raw of keys was not working at all: 9 O L . I've ordered and replaced with new one, but problem didnt change a bit :( these keys still not working. Can anyone suggest where to look? Thank you.
BMorse
Joined Sep 26, 2009
2,675
Sounds like the keyboard encoder circuit could be defective, in which case, you may need a new motherboard. Check to see if the keyboard connects to a smaller board that is on the motherboard, or does it connect directly to the motherboard?
Danys
Joined Jun 6, 2013
5
So.. noone? There is no spare motherboard to test if this one is broken. It is not windows issue, cuz the same situation can be seen in DOS mode. Bios update didnt help either.
Danys
Joined Jun 6, 2013
5
Yep, extrenal and virtual keyboards working just fine. I've just checked circuits and wires - everything looks fine here too.. Im starting to believe that it could be motherborad chip, but maybe anyone would give me another idea to check.
THE_RB
Joined Feb 11, 2008
5,438
If you swapped in a new keyboard and the problem remains, it is with the something associated with that row, in either the motherboard or the wiring.
My vote would be the wiring, there is probably a flat cable connecting the KB to MB, the problem is likely a bad connection on one wire there.
Danys
Joined Jun 6, 2013
5
Problem was in a motherboard channel. Somehow it was interrupted. Now its all working. Thank you for your advices:)
