Hi, im posting because ive taken apart a few old keyboards trying to get the button boards to work with analogue synthesizers that use 555 and 556 oscillators... im wondering if anyone has experience with this, because the wires on these boards from the old digital keyboards ive salvaged are quite confusing ! if anyone has taken apart a keyboard youll know what i mean. the rubber push button pads, and then above them on the board are usually a small bit of semiconductor on the board, then goes out to all the way across the board to a cluster of wires, and there are generally two or three groups of clusters. lets say mine has 2... how would you even began to consider hooking this up to a oscillator ? should i just scrap the idea and make my own board with a line of resistors ? and where can i buy a long long narrow peice of PCB to do this with ? lastly, if i wanted to re-use this one.. i suppose id have to sand the entire top of the pcb, then buy etching solution to get rid of the copper thats currently on the board and drill holes to put the stuff where i want on it and attempt to use thin wire to re-wire the entire thing ????
let me please hear your suggestions, ideas, and hopefully if anyone knows how to do this... maybe ill find a way. please keep in mind, the last thing i want to do is to soak the pcb to remove all the copper and rewire it.
