Key ringer
Discussion in 'General Electronics Chat' started by vimal333, Apr 19, 2012.
  1. vimal333
    Nov 10, 2011
    I'm trying to built a key ringer (which can be attached to the key as key chain so that it can be easily found out with the help of the beep sound when misplaced). I know its available in the market but wanted to make one of my own.i figured it out that it should have a RF transmitter receiver with a beeper attached tot he receiver ,but dunno really where to start. This is the one I'm talking about http://www.keyringer.com/ .Saw many circuits like whistle key finder etc but this the one i really want to make.:)
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    Yeh, but how do you find the key ringer when you lose it?
  3. DenisM
    Apr 23, 2012
    20
    I remember seeing those years ago. They were not activated by a remote. You would only lose the remote anyway :(
    They were activated by clapping your hands - making some noise - and the device would respond by chirping.
    So I reckon you need a device with a small microphone and a small speaker. It would have to come on only in response to a sudden sharp sound, otherwise it's battery would run down with ambient noise.
    No remote control device would make sense.
    Good luck :)
  4. DenisM
    Apr 23, 2012
    20
    Hey! I've just read the full site you referred to http://www.keyringer.com/
    and it does seem a sensible solution. Each device can find another. So you keep one of them safe always - as suggested - stuck to your fridge.
    Still - the temptation to walk about with the 'safe' one when something is lost, would inevitably lewad to its loss also :(
    It's easier to make a whistle or clap as neded
    D.
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Unless you want to build an RF receiver/transmitter from scratch I recommend low power RF ICs from Micrel or Linx Technologies.
    There are several different types available.
    Example:http://www.micrel.com/_PDF/micrf002-022.pdf
    Your major obstacle is battery capacity. There exist "long" range passive transponders but that's a much more complicated project.
    The above mentioned low power UHF receivers need to be used in polled operation, in order to save current.
