Key FOB transmiting from a rotating platform
Discussion in 'The Projects Forum' started by KMoffett, Jan 4, 2016.
  1. KMoffett
    Thread Starter AAC Fanatic!
    Dec 19, 2007
    2,584
    234
    I would like to send the state of three switches on a rotating platform to a nearby stationary circuit. The platform would rotate from 15 to 200 RPM. I'm wondering if anyone has done this using a multi-button key FOB transmitter on a rotating device, sending to a stationary receiver. Only one switch would be active at any given moment.
    Ken
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Thanks. That looks like it may be the best solution, at that price. But I would still like to know if a rotating FOB transmitter might work.
    Ken
  4. Lestraveled
    May 19, 2014
    1,957
    1,218
  5. KJ6EAD
    Apr 30, 2011
    1,426
    364
    Of course the fob will work as long as the range limits are respected. At a few hundred MHz and close range, the antenna orientation and doppler shift will be insignificant.
  6. Brevor
    Apr 9, 2011
    282
    56
    The tire pressure sensors on cars work that way.
  7. KMoffett
    Dec 19, 2007
    2,584
    234
    That is what I was wondering. So either the FOB or the slip ring options should work.
    Thanks guys.
