KCL and KVL
Discussion in 'Homework Help' started by John Ramelb, Feb 23, 2014.
  1. John Ramelb
    Feb 2, 2014
    26
    http://i.imgur.com/IDrSyCY.png ( THe VOLTAGE AT V1 is same as V2 I mean the positive terminal and negative terminal Is just like V2 I didnt see that when I editin in paint.)
    please help me deal this problem. I solve this problem but I don't know where I my solution got wrong.. I try multisim to check my answer but in Resistor 10 it measure 10 amps in multisim. I dont know where I got wrong in my solution. Please help me. PS I dont want to use mesh/nodal . I just want to master the Kirchoff's law Thanks to all of you !!!!
    I came up with my solution.
    loop A:
    100 V - 10(I1) - 5(I2) = 0
    10(I1) + 5(I2) = 100 V
    loop B
    50 V - 2(I1 - I2) - 2(I3) + 5(I2) = 0 (* -1 SO THAT I WILL GET POSITIVE VALUE OF I1)
    2(I1) - 7(I2) + 2(I3) = 50V
    loop C:
    50V - 3(I1 - I2 - I3) + 2(I3) =0
    3(I1) -3(I2) -5(I3) = 50 V
    USING DETERMINANTS I GET THE VALUE OF D AS:
    (I1) (I2) (I3) (V)
    10 5 0 | 100
    2 -7 2 | 50
    3 -3 -5 | 50
    D= 490
    SOLVING FOR I1 USING DETERMINANT
    D1 =
    100 5 0
    50 -7 2
    50 -3 -5
    D1 = 5850
    I1 = D1/ D = 5850/ 490 = 11.938 A
    D2 =
    10 100 0
    2 50 2
    3 50 -5
    D2 = -1900
    I2 = D2/D = -1900/490 = -3.8775 A
    D3 =
    10 5 100
    2 -7 50
    3 -3 50
    D3 = -250
    I3 = D3/D = -250/490 = -0.510 A
    let me know where did i got wrong . I just want to Solve this using KVL and KCL please help me thanks !!!!!
  2. anhnha
    Apr 19, 2012
    776
    48
  3. anhnha
    Apr 19, 2012
    776
    48
  4. anhnha
    Apr 19, 2012
    776
    48
    I guess you got 10A through the 10 Ohms resistor because you reversed V2 in your simulation.
