KBLC MOD help
Discussion in 'The Projects Forum' started by cimber, Nov 20, 2011.
  1. cimber
    Oct 21, 2010
    9
    I bought this controller to replace one I broke. Link below!
    http://www.ebay.com/itm/K-B-Electro...t=BI_Control_Systems_PLCs&hash=item2a0e122c38
    You see the little blue control box? The one that has the plastic on it. Well the one I had that broke didnt have that on there. It had wires where it screwed into the green box.
    My question is..
    Can I remove that light blue little box and use the one with wires that connect to the green box to control the speed?
    Thanks!
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    should be good to go assuming your little green box is a variable resistor with a value of about 20K ohm.
  3. cimber
    Oct 21, 2010
    9
    I took the one off the board. While running the motor a wire came lose and sparked. Now when I try to control the speed with the little blue controller that I have wired in, it wont slow down. As soon as I plug it in, it runs wide open. I looked over the boards and there was no fuses blown or any black marks on any board or wiring. Could the little blue controller be bad? Any help please!
    thanks!
  4. cimber
    Oct 21, 2010
    9
    Wleep, did something to the controller now the power wont work. LOL. So this is what im looking for. A controller that is actually made for the motor I have.
    Here is the specs for the motor.
    180 VDC
    1/8 HP
    265 RPM
    .67 Amps Cont. Duty
    Can someone point me in the right direction. Im not looking to spend to much. I want it to have a speed control that I can wire in. Like the one that is in my first post.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    And the controller you purchased:
    I'd suggest getting a motor controller from a reputable distributor and connecting it as their instructions show. Otherwise, you will most likely keep burning them out, and possibly harming yourself to death.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Just because the motor is rated at 180VDC, it doesn't absolutely need to have that much voltage to run. It will only run at a slower speed with less torque, which, without knowing the end use, may or may not be a problem for the OP. KB DC drives are relatively cheap, reliable and easy to use. At only 265 RPM, I would guess that this motor has a gear-head as an integral part.
  7. cimber
    Oct 21, 2010
    9
    What is a good cheap place to get controllers?
  8. BillB3857
    Feb 28, 2009
    2,402
    348
