So, what is your questionI need to simplify this : UVWX + UV'WX + U'V'WX + U'VWX + UVW'X' + UVW'X + U'VW'X' + U'VW'X by using karnaugh maps
They are typically written as:yeah but I dont know if is right? can you please tell me if I did right, and I got the right simplification
|wx | wx'| w'x' |w'x
uv | 1 |0 | 1 | 1
uv' | 1 |0 |0 |0
u'v' | 1 |0| 0| 0
u'v | 1 |0| 1 | 1
Simplification : wx + vw'
So is correct? because I dont know if I can group 4 1's even if they are parallel and not square shape, like the 1's on red.They are typically written as:
Simplification : wx + vw'uv\wx|00 | 01| 11|10
00|0|0| 1 |0
01| 1 | 1 | 1 |0
11| 1 | 1 | 1 |0
10|0|0| 1 |0
but as long as each header does not differ from a neighboring header by more than 1 bit, it will work...
Your logic seems sound and your process correct.
As you can see, there is another way to group 4 1's, but then you have another, superfluous term. This would appear to be the reduced version...
You should also note that grouping the max-terms will be the same number of gates...
Yes, you can group them provided they are next to each other: line, square, across boundaries, and even at the corners...So is correct? because I dont know if I can group 4 1's even if they are parallel and not square shape, like the 1's on red.
