So basically, I'm trying to design a logic circuit which does the following:
There's a big gate that gets opened by stepping on a pressure plate. There are 4 plates total, 2 on each side of the big gate. The gate is opened when any (or both) plates are stepped on. Find the simplified boolean function to make this work.
So my input/output look somewhat like this. (Assume S1,S2 is inside and S3,S4 is outside)
S1 S2 S3 S4 | F
0 0 0 0 0
0 0 0 1 1
0 0 1 0 1
0 0 1 1 1
0 1 0 0 1
0 1 0 1 1
0 1 1 0 1
0 1 1 1 1
1 0 0 0 1
1 0 0 1 1
1 0 1 0 1
1 0 1 1 1
1 1 0 0 1
1 1 0 1 1
1 1 1 0 1
1 1 1 1 1
Then, there's a problem. There's few cases where some inputs are an impossibility. For instance, you cannot step on the outside plate and inside plate at the same time or step on more than 2 plates at the same time so this eliminates many possible inputs (Such as 1,1,1,1 or 1,0,0,1). How do I eliminate this condition to simplify my equation as much as possible when drawing my K-map?
S1 S2 S3 S4 | F
0 0 0 0 0
0 0 0 1 1
0 0 1 0 1
0 0 1 1 1
0 1 0 0 1
0 1 0 1 1
0 1 1 0 1
0 1 1 1 1
1 0 0 0 1
1 0 0 1 1
1 0 1 0 1
1 0 1 1 1
1 1 0 0 1
1 1 0 1 1
1 1 1 0 1
1 1 1 1 1
