Karnaugh map decomposition
Discussion in 'Homework Help' started by transistortransistor, Jan 21, 2014.
  1. transistortransistor
    Oct 9, 2013
    11
    Hello everyone,
    I need to implement the following function:
    f(A,B,C) = (sum of the miniterms 2,4,5,6)
    I can only use 4 NAND gates with two inputs. A,B,C complement are not available.
    The question suggests that I should use K-Map Decomposition.
    My question is: how am I supposed to use this technique? should I magically know how each operation looks on a K-map and think of ways to gather them?
  2. MrChips
    Oct 2, 2009
    12,657
    3,461
    You are supposed to have been shown how to draw Karnaugh maps.
    Draw a Karnaugh map for three variables A, B and C.
    Show the minterms 2, 4, 5, and 6 on the map. Then we'll guide you from there.
  3. transistortransistor
    Oct 9, 2013
    11
    Ok, whats the next step?
  4. t06afre
    May 11, 2009
    5,939
    1,222
    We do not mind helping in this section of forum. But we will not just serve you a solution on a silver plate. In this case it is quite apparent that you have not done much reading in your books or lecture notes. Anyway try to read this http://www.uotechnology.edu.iq/dep-eee/lectures/1st/Digital techniques/part2.pdf Then feel free to come back with your questions
  5. MrChips
    Oct 2, 2009
    12,657
    3,461
    Group the 1s in powers of 2 (pairs, quads etc.) and write them down as sums of products.
  6. transistortransistor
    Oct 9, 2013
    11
    Hello MrChips, thanks for helping.
    Anyway, I know how K-Maps works.
    In this case, I would use 3 NAND's to get the "complement" of the variables + 3 NANDS to the products (BC, AC, AB) + 1 NAND with three inputs to get the final function.
    But the question says that I need to use just 4 two input NAND.
    And then it suggests K-Map decomposition.
    Here a image of an example:
    Thats why I said "guess". It's not guessing, but I would need to know beforehand how AND/ORS or any other operation look on K-MAP so I would be able to gather them and get my function.
  7. MrChips
    Oct 2, 2009
    12,657
    3,461
    If you know how K-Maps work then what is your question?
  8. transistortransistor
    Oct 9, 2013
    11
    It's about k-map "decomposition"
    Please, take a look at the example of my lecture slide:
    http://postimg.org/image/ed1e2mlqn/
  9. WBahn
    Mar 31, 2012
    18,096
    4,920
    So what on earth is preventing you from drawing the K-Map for A AND B and/or A OR B and seeing what it looks like on a K-MAP?
