Hi. I'm new to the board, and pretty new to electronics in general. I'm building a foot control for my Kaoss Pad II (a touchscreen controlled effects noisemaker) so that I can control the sample functions with my feet. Ive demolished an old Korg Toneworks multi effects pedal for parts and the casing, and I'm a little stuck.
The board is full of lovely bits for me to steal. The buttons on the top of the enclosure are big plastic pads, and trigger tiny little buttons underneath, and id like to keep the board in there. I know that the best way to go around this is to score off the connections with everything and then just use wire to connect the limited bits i need to connect, but I've come across a problem.
These buttons are unlike anything I've used before. I need to send a wire from one of the corners to a pin on a midi connector, but i have no idea which one, and the same goes for wiring up the led and a resistor so I know if its on or off!
Any suggestions?
Cheers,
Chris
Any suggestions?
Cheers,
Chris
