K243 motor controller
Discussion in 'The Projects Forum' started by Erac, Aug 14, 2010.
  1. Erac
    Aug 7, 2010
    8
    I bought this motor driver ( K243) http://secure.oatleyelectronics.com/files/K243notes.pdf ,but I want to replace the potentiometer that controls the direction of the motor (When the potentiometer is centered the motor does not turn....Rotating it clockwise makes the motor turn one way...anticlockwise..the other..).
    I want the direction of my motor, to be controlled by my arduino micocontroller. Do you have any idea how?
    Hope for your support,
    Erac
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    I remember making this circuit when I tried to PWM a motor.
    The motor does rotate both ways, I am used to PIC's. I think it is possible to use other uC's. I think you have to use DAC ports. Or a digital pot interfaced with the controller
    Erac likes this.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    If you follow the instructions for using a R/C servo pulse it should work.
    Just send a 1-2 ms pulse every 20ms or so. 1.5ms would be centered, 1ms it would rotate full speed one way, etc.
    Erac likes this.
  4. campeck
    Sep 5, 2009
    194
    you could use the arduino to control a digital pot instead of a manual one.
    I did this with a BASIC stamp that controlled a digipot on a 555 that controlled the pulse width going to a motor driver chip for speed control.
    Erac likes this.
  5. Erac
    Aug 7, 2010
    8
    Thanks! markd-77 now I get the concept...some question for clarification:
    Motor Direction Control by arduino microcontroller
    How will i wire the arduino to change the direction as replacement for the potentiometer? It says in guide that the potentiometer is wired to terminals B C and D.. Where/what pins of my arduino should I connect? Where will I connect it to my K243
    Motor speed control
    I will connect the GND of my K243 to the GND of my arduino microcontroller and SIG ( k243) to the digital pin that is being used by my arduino microcontroller.. Is this right?
    My motor speed and direction microcontroller: http://secure.oatleyelectronics.com/files/K243notes.pdf
    Erac
  6. Erac
    Aug 7, 2010
    8
    What digital potentiometer interfaced with a microcontroller do your suggest?
    Thanks,
    Erac
  7. Erac
    Aug 7, 2010
    8
    Thanks campeck! I think this would be a great alternative
