Just making sure on a component value ID
Discussion in 'The Projects Forum' started by Videodrome, Jul 17, 2010.
  1. Videodrome
    Nov 12, 2009
    63
    have a little green mylar cap with the printing '2A103KT' upon it. this stands for .01mf correct?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yes. The value is actually 10,000 picofarads (10 followed by three zeros), or 10 nanofarads.
    Videodrome likes this.
  3. Videodrome
    Nov 12, 2009
    63
    thanks alot!
  4. Videodrome
    Nov 12, 2009
    63
    hey again folks! have a few trim pots in which i need to decipher the value and figured id post it here than make another thread and waste space. i am listing the complete factory labeling just to be thorough as they appear printed atop the trims packaging. thanks again folks!
    POT 1
    3006P 504 0210A9
    POT 2
    3006P 105 0402L6
    POT 3
    3006P 105 0210H4
    POT 4
    3006P 205 W6000
    POT 5
    3006P 205 W8186
  5. marshallf3
    Jul 26, 2010
    2,358
    201
    Unless the 504, 105 etc are indicators of value why don't you just meaure them with an ohmmeter?
    When you can buy them from Harbor Freight for $2.99 or sometimes $1.99 during one of their very frequent sales it makes no sense not to own one, nor does it make much sense to be experimenting without one.
  6. marshallf3
    Jul 26, 2010
    2,358
    201
  7. retched
    Dec 5, 2009
    5,201
    313
    I agree. Are the POTs out of the circuit or are they still soldered in?
    If you switch your multimeter into OHMS(RESISTANCE \Omega ) mode, then use one probe on the wiper pin (middle if there are 3 pins) and one on the other pin. (Or either outside pin if there are 3)
    Turn the adjustment shaft all the way clockwise, read the meter
    All the way counter clockwise, read the meter.
    It should go from 0(zero) to something. This 'something' is what you are interested in.
    Typical values are:
    1k or 1,000 ohms
    10k or 10,000 ohms
    100k or 100,000 ohms
    and
    1M or 1,000,000 ohms.
    Here is some info on testing them, and using them:
    http://www.allaboutcircuits.com/vol_6/chpt_3/6.html
    http://www.allaboutcircuits.com/vol_6/chpt_3/7.html
    here is a page from MOUSER for the 3006P series of POTs:
    http://ca.mouser.com/ProductDetail/Bourns/3006P-1-501LF/?qs=GxOdHD6aiJ5yu%2bcpsoB/dw==
  8. marshallf3
    Jul 26, 2010
    2,358
    201
