Just for Proffisional
Discussion in 'The Projects Forum' started by eng.zaid, Dec 6, 2007.
  1. eng.zaid
    Dec 6, 2007
    10
    Is ther any way to make TV screen work as an oscilloscope,and if there is please may tell me.
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    There are ways of doing this, but a TV screen won't give a good oscilloscope. Traditional oscilloscopes use electrostatic deflection while TV image tubes use magnetic deflection. Magnetic deflection is more powerful and indicated for large sized tubes. The vantage of electrostatic deflection is that it allows much more fast changes and more control over the cathodic ray. There is another factor you have to take into account, and that is the persistance. Oscilloscope tubes have longer persistance, desirable for that particular function.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    What does "profissional" mean? Does it mean "in favor of fishing?"
  4. Ron H
    Apr 14, 2005
    7,050
    657
    I believe it is similar to "antifusional".
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A television converted to an O-scope will at best give you a 20KHz sweep.
    There are lots of other options out there. Since you already have a computer, and it probably has a sound card - you have most of what you need for a low-cost O-scope.
    You can download Winscope from this page; it's the software that uses your sound card as an input device for a simulated oscilloscope.
    http://www.mitedu.freeserve.co.uk/Downloads/download.htm
    Have a look at this page for more ideas:
    http://www.geocities.com/lptscope/
  6. eng.zaid
    Dec 6, 2007
    10
    thank you all for your replyies
  7. 3BwEH
    Feb 25, 2007
    33
    i believe he meant to say professional!
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    All you professional engineers who get excited at the thought of converting a 42" LCD Television to an oscilliscope please raise your hands. I'm detecting a distinct lack of enthusiasm for this concept. If you want an oscilliscope then get an oscilliscope.
  9. cumesoftware
    Apr 27, 2007
    1,330
    11
    LCD? In my opinion, doing that is a waste of money and the oscilloscope it may give won't be that great.
    Nevertheless, I'm looking forward to see that if you have the funds.
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes it is a complete waste of time with any television monitor, that was kind of the point I was trying to make.
