I have a 2N7000 Transistor,does the N mean it's a NPN type? also what would happen if it was put in round the otherway? Any help would be gratefully accepted.
Bazzer.
Bazzer.
The N has nothing to do with the polarity of the transistor.I have a 2N7000 Transistor,does the N mean it's a NPN type? also what would happen if it was put in round the otherway? Any help would be gratefully accepted.
Well I didnt blow myself up, reversing transistor C6 made no difference at all, the only thing is I'm back to having an earth fault light on, as I've said before I'm not an electrical engineer,I was a design engineer so I can read and understand drawings, I can copy an assembly, which is how I have put two of these switches together,The pictures that I used to work from it's worth noting are of one of the early ones that worked ok, so I'm at a loss as to why I'm having so mutch trouble.Hi Waynen,
Q1 is top left corner above C6, any way I've decided to put another one together and turn the transistor round & see what happens, if you don't see any more posts from me you know it failed,
Bazzer
