Just a quick question about Real 3 phase power
Discussion in 'Homework Help' started by Amanda_Riley, Apr 1, 2011.
  1. Amanda_Riley
    May 12, 2010
    22
    The equations to find real power is:
    P = 3 x Vphase x Iphase x cos(v - i)
    or √3 x Vline x Iline x cos(v - i)
    My question is if you have a delta connected 3 phase system and have
    Vphase = Vline = 120 angle 0
    Iphase = 41.6 angle -36.87
    Iline = 72.05 angle -66.87
    Would you use the angle of 36.87 for both the real power equations?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    How did you arrive at ...
    Vphase = Vline = 120 angle 0 ?
    The phase(line)-to-neutral and phase(line)-to-phase(line) voltages can't be the same.
  3. Amanda_Riley
    May 12, 2010
    22
    its delta connected - delta source and a delta load so no line to neutral line
    Phase voltage (Vab) = Line voltage(VAB)
    Line current = √3 x phase current
  4. subtech
    Nov 21, 2006
    123
    5
    In short, the answer is yes.
    The phase measurement (some call this the winding current) is the current magnitude and angle to use in your calculation.
