Just a question
Discussion in 'Homework Help' started by aceminer, Nov 5, 2011.
  1. aceminer
    Aug 26, 2011
    21
    Hi guys,
    Just to check, is there any exam papers i could find on the net provided with solutions as my digital logic exam is just round the corner. Would appreciate greatly any material or exam papers. I am a Year 1 CS student anyway.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Read through This
    It will help you a lot. Especially since it is FREE too!
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  4. aceminer
    Aug 26, 2011
    21
    Hey bertus, thanks for the link but they are apparently too hard for me to understand. I am only a Year 1 student so the course i am undergoing is relatively introductory so do you have any other links which are relatively less complicated. To be honest, i couldnt even understand the questions or the answers in the worksheet.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    Everything in the worksheet and quiz is covered in the link I posted.
  6. aceminer
    Aug 26, 2011
    21
    Well i have a question which goes like this:
    Given an Equation :
    F = A'B'CD' + B'C'D + A'B'C' + AB'D
    use a 4x1 multiplexer with an enable input plus other gates
    draw out the circuit based on this equation. Anyway the enable is active-low.
    I do have the answer but i cannot seem to understand why do they use A and C inputs as the select bits whereas the D inputs are belonging to the 4 x 1 multiplexer with one input being constant. Could some1 kindly please explain to me.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Skip to Here and draw out the truth table for the expression.
    From there, look at the behavior of a 4-1 multiplexer with enable.
    The ' as in A' means NOT A, and AB means A AND B, A+B is A OR B, and A'B is NOT A AND B
    It's just a system of notation for text discussion of logic.
  8. Georacer
    Nov 25, 2009
    5,151
    1,266
  9. aceminer
    Aug 26, 2011
    21
    Hi. Thanks a lot guys! I think i figured my question and answer out. You guys are a great help!
