I'm looking to add a small gasoline engine (5hp) to charge a 48 vdc electric manlift during and after operation. Trying to figure out best, economical way to do this. I understand most auto alternators will put out 60 volts without ruining diodes, stator windings. Can I use an automotive type remote mounted regulator set to ~14.2 volts to control field voltage if I use taps off the first two batteries for voltage sensing? The battery pack consists of 8 6-volt golf car batteries in series. I'd be happy with even 30A. It would be nice to supplement the battery pack during operation. Electric motor on manlift is rated at 6hp and runs mostly intermittently. Permanent magnet rotors are available for delco alternators with windings and diodes made for 48 volts, but how would I control voltage after batteries charged. The people who use these for wind generators usually dump load into a big resistor (water heater) after battery voltage reaches about 56. I guess I could use a voltage sensing relay and a soleniod to idle down at this point. I'm seeking suggestions and experience. I've thought also about just getting a small genset and a 48 volt charger, but I'm concerned the charger would take a hit if I ran the lift while charging. I could put in a disconnect relay that would take the charger off line when the lift runs. Would it be better to switch the input or output in this circumstance, or would this ruin the charger?
