Junction field-effect transistors errors
Discussion in 'Feedback and Suggestions' started by Unregistered, Sep 3, 2007.
  1. Unregistered
    Thread Starter Guest
    You say the Gate is like the emitter of a BPolar device; I believe you mean to say it is like the Base of a BPolar device.
    Also, in your decrete device cross section (figure a), I think you have the Source and Gate switched.
  2. jrap
    Administrator
    Jun 25, 2006
    966
    202
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I can't find where it is in the text, but yes you are right.
    And the diagram is http://www.allaboutcircuits.com/vol_3/chpt_2/9.html#03303.png - yes you are again correct that the source and gate are the wrong way round on the first (a) diagram.
    Thanks for the corrections.
    Dave
  4. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    Thanks Unregistered user for pointing out the errors. I have made the following changes to the ibiblio master copy:
    The gate is analogous to the emitter of a BJT.
    To:
    The gate is analogous to the base of a BJT.
    Image 03303.png has been fixed.
    Unregistered user: I f you would like to be listed under your name on the contributors page, please contact us.
