Jumper Links
Discussion in 'General Electronics Chat' started by ISB123, Aug 2, 2015.
  1. ISB123
    May 21, 2014
    1,240
    531
    Hello,I have a project of mine which is going to require few jumper links and since I'm running low on copper wire I was thinking of using carbon steel wire to be used as a jumper,dimension would be 3cm L x 1mm A.
    So what do you think guys?
    Last time I used steel wire in electrical project was when I was building a project with NE555,it didn't end up good,PSU went into protection mode:eek:.Not sure because it was from steel wire overloading the PSU or short circuit.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    ISB123 likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    Don't you have any store close by you can buy some telephone cable etc? very cheap for a couple of feet/ 8 conductor single strand.
    Max.
    ISB123 likes this.
  4. ISB123
    May 21, 2014
    1,240
    531
    How i didn't remeber that.Got some 50-60ft of telephone cable:D.
    MaxHeadRoom likes this.
  5. KeepItSimpleStupid
    Mar 4, 2014
    1,250
    218
    You should get some "0-ohm resistors" which are designed to be jumpers.
  6. ISB123
    May 21, 2014
    1,240
    531
    Cant find those anywhere.
  7. #12
    Nov 30, 2010
    16,655
    7,293
    All I can say is, steel is hard to solder. :oops:
  8. KeepItSimpleStupid
    Mar 4, 2014
    1,250
    218
  9. ISB123
    May 21, 2014
    1,240
    531
    Thanks but I don't order from digikey. I managed to find jumpers on my distributors catalog they hid it pretty well.:mad:
  10. KeepItSimpleStupid
    Mar 4, 2014
    1,250
    218
    I take it, you like the idea?
  11. ISB123
    May 21, 2014
    1,240
    531
    Yeah,gonna order few hundred. [​IMG]
