The short story:
I'm looking for a schematic of a simple circuit that runs on 12VDC, outputs 0 to 12 volts by using a 65K POT, and handles up to 1A.
The long story:
I have an old man lift (80's model), that has a bad joystick. It actually has 3 of these joysticks, so I am able to determine how the defective one is suppose to work. And I've taken one of the good ones apart to get some good photos of the board. It's old technology, so I'm thinking it should be either easy to fix or easy to build a replacement board. I've found a used replacement joystick for $700, but it's really only a $10 pub if I can make one. It looks like this photo1. It's function is not complicated at all. It has 4 wires connecting to it, 2 of which give it power, 12VDC & GND. The 3rd terminal goes high (12VDC) when the joystick is moved out of center position, by a microswitch in the joystick.
This PCB is mainly all about the 4th terminal, which tells it how fast to move forward and backward. It put's out 6VDC at center. It goes from 6 to 12 VDC in one direction, and 6 down to 0 volts in the other direction. It's basically just like these handicapped wheelchair joysticks that I've worked with, except they are 5 volts, with a 2.5 volt center.
The defective one puts out the full voltage as soon as I move it in either direction, even the least little bit. I found one burnt diode on it and replaced it, but it still doesn't work. It looks like one of the power transistors (2N4918) is burnt but not sure. Everything is so epoxied that you can't really remove anything to test it. So I'm thinking it'd be easiest to just make a new board. I've done a lot of work with Arduinos, and custom PCB, so this should be easy to make. I just need a schematic of a variable voltage supply. Well, not the power supply, because I already have the 12VDC, but need to output it as 0 to 12 volts. Would someone know of a little circuit that puts out 0-12VDC, controlled by a 65K POT. That's the original POT on the joystick. The power transistors on the old board are rated at 1A, so that's what my new board should be rated at.
Thanks.
The long story:
Thanks.
