2 Little Joule Thief circuits, I noticed that with this circuit if you don't use the Resistor on the Base pin of the transistor it will gladly pull up to 1/2 an amp at 1.28volts .... but regardless of if you use the Resistor or don't, the LED brightness stays roughly the same up to about a 150 ohms.
