Joint probability
Discussion in 'Math' started by boks, Jan 9, 2009.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    If
    f(x,y) = 4xy, for 0<x<1, 0<y<1
    f(x,y) = 0, elsewhere
    What's the probability that X<Y?
    It seems likely that the probability is 0.5, but how can I show it matematically?
  2. steveb
    Jul 3, 2008
    2,433
    469
    Use can use symmetry here. The problem is symmetrical in the sense that x and y can be swapped and the problem is the same. Hence, the probability that x<y must equal the probalibity that y<x.
    P=0.5, by symmetry.
  3. boks
    Oct 10, 2008
    218
    OK, thanks!
    If(x,y)=cxy^2, what would I have to do?
  4. steveb
    Jul 3, 2008
    2,433
    469
    I can start the approach.
     P=c\; \int^{1}_{0} x \; \int^{x}_{0} y^2 \; dy \;dx
    Simply integrate overt the area of interest. The geometry is simple in this case, so establishing the limits of integration is easy.
  5. boks
    Oct 10, 2008
    218
    Makes sense. Great stuff.
