johnson counter
Discussion in 'Homework Help' started by bian momani, Feb 22, 2010.
  1. bian momani
    Feb 22, 2010
    6
    hi
    how to Design Johnson counter using 74ls191,74ls194,JK flip flop,and other component if needed.????????????????????????????????
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. bian momani
    Feb 22, 2010
    6
    hi
    this link not help me ...........thanx any way
  4. atferrari
    Jan 6, 2004
    2,670
    785
    Get the datasheet of CD4017, proabbly the most popular ever amongs hobbyists.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I don't understand. Was there something wrong with the link?
    You start with a shift register, and an inverter. Take the output of the most significant stage and route it back to the shift register input through the inverter. Reset the shift register to all ones or all zeros. Now each time you clock the shift register you will see either ones or zeros walking through the shift register.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Of course, there's also that little circuit (the NOR gates in the 4017) that gets it into the correct sequence if it should find itself in one of the "short cycle" states. All Johnson counters with 3 or more stages need that function.
