Well, it is, but there are somethings that i don't understand very well...
For example, i do understand how JK works internally but not how D works, so i cant compare them.
I do know that JK is more flexible then D because it has two entries J and K, but this is the only i know to compare them...
The two FFs have differences in their internal circuitry which of course leads to differences in behavior.
The first can be identified by looking at the two schematics.
The second can be seen by drawing the truth tables.
Which one are you interested in?
You can also convert from one FF to the other with the adequate components.
well, i cant find the truth table for the d FF but i just learned that my work will be only with JK! I'm already made the circuit but the led is not turning on.
The circuit needs to read 0011 and 0100 (from now on i apologize because i don't know how to say somethings about my project in English, but i'll try my best) i've made the projection of the states, which are the current state and the following state, my projection is a moore machine.
With that and the transition table of jk i've calculated the fk entries (I forgot to mention that i have to dual flip-flops jk) and with that i've got the karnaugh maps and from that the boolean expressions.
With this i've made my circuit but it still doesn't work. What do you thing i'm doing wrong?
I need to build a counter with 2 dual flip-flops jk that needs to process 0011 and 0100.
I've already done it, but it isnt working and i cant find the mistake.
What i've done was first make a Moore machine that would read those 2 numbers.
From that i've made the entries and exits table, and from that i've made the karnaugh maps. From the maps i got the boolean expressions and with them i've made my circuit.
The sets are connected to the Vcc and the resets are connected to the GND.
All clocks are connected with each other because this is a synchronous circuit.
My only problem is that after making these things my led isnt turning on...
Your state diagram is flawed, that's why your circuit isn't working.
Consider these cases of input:
00100
This one should be accepted and lead to the final stage. However, it gives ABCDBC.
010011
This one should also be accepted as 0011 and end in G, but instead it goes ABEFGAA.
Spend some more time working on your transition diagrams. Post a new one and we 'll comment on that.
Okay, you need patience and insight for this task. You did the right thing drawing the two paths from A to G, using your two desired inputs.
You now need to take into account all the possible cases of input.
For example: If you get 000000011, you need a point to loop around 0 and wait for those two aces to get you to G. That can happen if you loop the 0 on C instead of returning it to B.
On the similar case of 000000100, since you loop around C (as I suggested earlier), you will go to D on the 1 and then you need to go to F on the next 0, since you now have 010 as your last
The input 00110100 must end in G. That means that after you go to G the first time for 0011, on the arrival of 0 you must go to B, not A, in order to follow the lower path on the second run.
No one said it was easy. There are many cases to take into account and unfortunately there isn't an algorithmic way to design a word recognizer (at least that I know of).
Keep your spirits up and try to invent more and more test cases. Each time you make a change be sure that the previous inputs still work.
You did not give the part number of the flip-flops you are using.
Check the data sheet. It is not usual that you would connect the SET to HIGH and the RESET to LOW at the same time.
You begin this discussion by asking the differences between Flip-Flop's type J-K and D.
Then, after wondering, you mention that you have a counter with 2 dual Flip-Flop type J-K's and you have to light a LED when the counter count is from 3(0011) to 4(0100).
Certainly, with that kind of Flip-Flip you can perform a 4 BIT's counter which would count from 0 to 15.
Which you must do is detect when the counter is in the states 0011 or 0100.
I suppose that BIT of the extreme right is the least significant (LSB) and the extreme left is the most significant BIT (MSB) in the binary numbers that show
The first thing you do is counter: from 0 to 15.
Then, with AND and OR gates, to detect when the counter reaches the number you want to turn the LED on.
So take a look at the attached image for compliance with the provisions of your project.
