JFET/MOSFET Characteristics
Discussion in 'Homework Help' started by seracht, Nov 12, 2007.
  1. seracht
    Nov 12, 2007
    I have a couple questions about JFETs and MOSFETs.
    1) Explain the three terminal characteristics of a JFET?
    I think I got this - Source, drain and gate. I kind of figured out how it works. Electrons from the source go towards the drain while the gate limits how much of the electrons actually go there.
    can you please confirm?
    2) Compare the JFET characteristics to a Bipolar Junction Transistor (BJT). Include a sketch of the BJT characteristics and include saturation and forward active regions in the sketch.
    I am not sure where I should start here
    MOSFET
    3) Qualitative describe the operation of a n-channel enhancement MOSFET
    Not sure where to start here as well.
    4) Compare the MOSFET characteristics with those of a JFET.
    Same as above.
    Thanks for the help.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Look around the International Rectifier web site. They have a variety of documents available that describe how FET's function and their characteristics. Get the data sheet of a power BJT like a 2N3055 to make comparisons. Also look up the data sheet for a JFET like the MPF102 (not the best, but very available) to make that comparison.
    You're close with #1, but no instructor will find that brief an answer acceptable.
