Can someone explain why this pJFET claims Rds(ON) of 270ohms to be "low"?
When the JFET is on, shouldn't we expect something like 0.003 ohms to allow maximum current through the open drain/source channel?
As I understand it from the tutorial, when the JFET is off (saturated gate/source junction), then the resistance should be high with a closed drain/source channel.
