Jennic jn5139 ADC
Discussion in 'The Projects Forum' started by Schniz2, Aug 29, 2010.
  1. Schniz2
    Apr 15, 2010
    22
    I am using the ADC on the Jennic board to digitise and transmit an analogue output from strain gauges connected in full-bridge configuration and i was wondering whether or not i would need an amplifier before inputting it to the ADC?.... the strain gauge output will be in the realm of milli-volts and will be battery powered.
    If so, i was thinking of using just an op-amp to improve the signal strength?
    Comments, idea's?
    Thanks :D.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Of course you will need an amplifier. The output from the bridge is the difference voltage between two points riding on 1/2 the excitation voltage.
    The most common way to get the signal and make it single ended rather then differential is to use an instrumentation amplifier.
