Java Maths Calculation?
Discussion in 'Programmer's Corner' started by Ben_C, Feb 29, 2012.
  1. Ben_C
    Thread Starter Active Member
    Oct 19, 2010
    65
    Hi ive been given the task of programming code that solves a calculation of variable inputs from the Scanner, from f and n. I've got upto the stage of inputting the variables and it compiles in cmd but thats it... I dont know have a clue how to expand it and put the values of f and n into the equation.
    gain = [275/(23^2+(0.5f)^2)^0.5]^n
    I've to use a do-while loop whilst gain and f are to be declared as a double whilst n is an int. The answer should be printed out to 2 decimal places and the program should only break out of the loop when a valid value of n has been entered. n can only be from 1 to 10.
    Example:
    Enter a frequency:
    100
    Enter the number of stages:
    Enter a value between 1 and 10 please try again.
    6
    gain = 15563.18
    Heres where I've got up to>
    Code ( (Unknown Language)):
    1.  import java.util.Scanner;
    2.  public class Assignment1
    3. {
    4.  public static void main (String [] args)
    5.  {
    6.  Scanner input = new Scanner(System.in);
    7.  System.out.print ("Please enter the frequency: ");
    8.  int frequency = input.nextInt ();
    9.  System.out.println (+ frequency);
    10.  System.out.print ("Please enter the number of stages:");
    11.  int stages = input.nextInt ();
    12.   if (stages >=1)
    13.   if (stages <=10)
    14.    {
    15.    System.out.println (+ stages);
    16.   }
    17.   else
    18.   {
    19.    System.out.println ("Enter a value between 1 and 10. PLease try again.");
    20.   }
    21.
    22.  }
    23. }
    I think the if and else statements are wrong these may need to be the do while loops Im not very confident with this :confused:
  2. nigelwright7557
    May 10, 2008
    488
    71
    //this is better
    if (stages>=1 && stages <=10)
  3. Ben_C
    Oct 19, 2010
    65
    Okay, so ive finally figured out how to do it just one simple problem which seems complex to me haha... Heres my code..
    1.
    2. import java.util.Scanner;
    3. public class Assignment1
    4. {
    5. public static void main (String [] args) {
    6.
    7.  Scanner input = new Scanner(System.in);
    8.
    9.  System.out.println ("Please enter the frequency: ");
    10.  double f = input.nextDouble ();
    11.  System.out.println ("Please enter the number of stages:");
    12.  int n = input.nextInt();
    13.
    14.        if (n > 1)
    15.        if (n < 10)
    16. do {
    17.  double G = Math.pow(275/Math.sqrt((Math.pow(23,2))+(Math.pow(0.5*f,2))),n);
    18.  System.out.printf ("The Voltage Gain is: %.2f", G);
    19.  n = input.nextInt();
    20.  }while (n > 1 || n < 10);
    21.
    22. else {
    23.  System.out.println ("Enter a value between 1 and 10. PLease try again.");
    24.  n = input.nextInt();
    25.     }
    26.   }
    27. }
    28.
    This code does what I want it to do when I put a value between 1 and 10 it calculates it. Above 1 and 10 it give the error message
    But say I put 4 or any digit after this message it just ends the program.. I should be able to enter a 4 after the please try again message and it calculate it. I need the Do { somewhere where the program executes all of the program. Ive spent like a whole day on messing around with the code but nothing.. Any help will be massively appreciated.
  4. cheezewizz
    Apr 16, 2009
    82
    10
    In that case you need to put the code for reading the inputs inside an infinite loop which you only break out of once valid input has been received...
    1. while(true)
    2. {
    3.       //read input
    4.       if(input_is_valid)
    5.             break;
    6. }
