Java:Calling a method from class
sirch2
Joined Jan 21, 2013
1,037
You cannot define methods in constructors but you can call them. Your problem here is that you do not construct an object of the type "temp", the constructor only gets called when you say new temp(); which you can do in you main method.
To be honest I think this will be my last response to you. I have better things to do with my time than give private Java tutorials. There are THOUSANDS of java tutorials on the web and as I advised in post #2 above, go and work through some of them.
justin2014
Joined Nov 26, 2014
24
Sorry for asking this much questions.As you said I'm now looking through tutorials.Thanks for your help.
darrough
Joined Jan 18, 2015
86
When you have a class there is a beginning bracket and an ending bracket. In between those two brackets you can declare and initialize variables, define methods, define constructors, define static initializers, put comments and define other classes. However, you cannot executable code in this space. This will never work.:
Code:
public class MyClass {
          myObject.myMethod();
It would be INCORRECT, but would WORK to do something like this:
          Object myObject = myMethod();
          public static void main(String args[]) {
                    System.out.println("STARTING JAVA PROGRAM");
                    MyClass myObject = new MyClass();
          Object myMethod() {
                   System.out.println("ENDING JAVA PROGRAM");
                    return new Object();
The correct way is like this:
                    MyClass myObject = new myClass();
          void myMethod() {
                    return;
Does this answer your question?
Moderators note: Please use code tags for pieces of code
justin2014
Joined Nov 26, 2014
24
Code:
          Object myMethod() {
          void myMethod() {
                    return;
Thanks for replying to this thread.To be frank I couldn't actually get the code:
Code:
It might be because I'm weak in java.I think that as you said you can't call a method directly from class in normal situations but you might using static modifiers.
justin2014
Joined Nov 26, 2014
24
You can call the method directly if you are initializing an instance or class variable. myObject is an instance variable.
Thanks.Now I think that means the problem lies with intialization.So only you could execute a method by instantiating it otherwise it should be static isn't it?
vpoko
Joined Jan 5, 2012
267
Yes, if you're calling a non-static method, you have to call it on an object (an initialized instance of a class) and not on the class itself. If you want to call a method without creating an instance of a class, you should make the method static.
darrough
Joined Jan 18, 2015
86
When you are initializing an instance variable you can call a static or non static method. However this should be a rare exception. It works, but it is usually bad code. There is no other circumstance where you can call a method outside of another method. The main method is one starting point. There are others, such as the Spring framework or the use of a containet, such as Tomcat.
