It pays to read the manual!!
Discussion in 'General Electronics Chat' started by MaxHeadRoom, Apr 23, 2015.
  1. MaxHeadRoom
    Thread Starter Expert
    Jul 18, 2013
    10,859
    2,525
    A while ago my son, who plays in a band, acquired a quality second hand British made tube amp.
    He seemed to be going through power tubes, a matched set of four replaced at a time.
    The amp has two ON switches, Power on 1 or 0, and a stand by SW. 1 or 0.
    Now intuitively, to me, you would put the Stand by switch on, wait a couple of minutes and then the main power on.
    After getting me to look at it after the last failure, I downloaded the manual.
    Evidently he (and I) had it backwards.
    The main power is switched ON followed by the standby ON after 2 minutes.!
    Power down in reverse.
    Hopefully this cures his expensive replacements.:(
    Max.
  2. #12
    Nov 30, 2010
    16,705
    7,354
    It will. Hitting a cold power tube with B+ poisons the cathode.
  3. cmartinez
    Jan 17, 2007
    3,698
    2,792
    Wouldn't it be better if you just designed and built a sequence-timer circuit and use a single switch instead of performing that operation manually every time your son intended to use it?
    atferrari likes this.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    I'm sure it needs a 555.
    ak
    SgtWookie likes this.
  5. #12
    Nov 30, 2010
    16,705
    7,354
    If only you had told that to the VOX corporation, about 60 years ago. :D
    Reloadron and cmartinez like this.
  6. cmartinez
    Jan 17, 2007
    3,698
    2,792
    Gosh... my first original idea... 60 years too late! ... :confused:
    Gdrumm and #12 like this.
  7. wayneh
    Sep 9, 2010
    12,394
    3,246
    My old Fender Tremolo amp is the same. Power-on first to warm up the tubes, then you come off stand-by a minute later. I always wondered whether you really need to hit stand-by before powering off, but it's good practice since it puts the toggle switch back to the start-up position. I don't believe you need any time lag between standby and power-off.
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    Convince me. What is the physics behind this statement?
  9. #12
    Nov 30, 2010
    16,705
    7,354
    What? Convince a person that believes current flows from positive to negative how a vacuum tube works? :confused:
    It's all just a joke created by the British manufacturer and perpetrated on people so ignorant that they actually need to read the manual. :D
  10. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    I do know that a low filament voltage in some types of cathode material can ruin a tube in seconds!
    Max.
  11. MrChips
    Oct 2, 2009
    12,648
    3,458
    I'm surprised you would see it the way you did.
    To me, power is power.
    Hence controlling the standby switch with the power off would have no effect.
    Apply power first. I can see that the standby position ON or OFF is ambiguous.
  12. cmartinez
    Jan 17, 2007
    3,698
    2,792
    Ok... now I declare myself officially confused
  13. #12
    Nov 30, 2010
    16,705
    7,354
    "0" is off, "1" is on. The idea is to power up everything except the B+ first, then switch on the B+ after the filaments are warmed up. ("Real" engineers don't believe this has any merit.) The only tube that gets high voltage on its plate(s) when its cathode is cold is the rectifier tube..if it has one. Silicon diodes changed this to almost zero delay for B+, eliminated the rectifier tube, reduced the number of turns in the B+ windings on the power transformer, and eliminated the 5 volt winding for the rectifier filament.
  14. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    An understatement.
    Standby ON to me would mean In Standby Mode, Not actually powered and ready to operate?
    Max.
  15. MrChips
    Oct 2, 2009
    12,648
    3,458
    I know what you're saying. Many times people are not semantically correct.
    The way it usually works on every piece of equipment, STANDBY in the ON position means it is no longer on standby.:rolleyes:
    That is, the ON label is overrides what we accept as STANDBY.
  16. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    I do not use this equipment but apparently according to my son, all his acquaintances he has spoken to are/were under the same impression and evidently have been misusing their amps in the same way!
    Much of this equipment has been purchased second hand and is a few decades old, so manuals did not come with the units.
    Max.
  17. MrChips
    Oct 2, 2009
    12,648
    3,458
    I have not seen the instructions in the manuals but my intuition tells me that for full operation,
    both POWER and STANDBY switches must be ON.
    So the sequence for power ON is
    POWER STANDBY
    OFF OFF
    ON OFF
    ON ON
    and back track for power OFF, as you have already described.
    Coincidentally, last week I was at the local music store checking out some guitars and amps and that is exactly how I operated the amps.
  18. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Evidently the unfortunate fact is that the majority of users of the equipment misinterpret the way to use it because of how the switches are portrayed and labeled, this would indicate that their needs to be a clearer indication of their usage.
    If I were a designer of such equipment, I don't see myself labeling it that way.
    Max.
  19. MrChips
    Oct 2, 2009
    12,648
    3,458
  20. wayneh
    Sep 9, 2010
    12,394
    3,246
    I don't see how there's any room for confusion. Warm up the tubes with the audio off, then turn on the audio. Seems intuitive to me, as MrChips noted in #17.
