Issue with LM7812 power supply
Discussion in 'General Electronics Chat' started by pal114525, Jul 9, 2015.
  1. pal114525
    Jul 3, 2015
    46
    I have seen the data sheet of LM7812 which is attached here also.
    It can drive inexcess of 1A current.
    But, in my circuit, while I am driving a coil in the load (of having 1.1mH inductance and resistance of the coil is 7 ohm) through class AB push-pull amplifier, I am able to get 800mA current, but the supply voltage gets reduced to 6V.
    Would you please explain me the fact and how to overcome this?
    Thanks & Regards.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What is the input voltage to the regulator?
    How big a heat sink is it on?
    I = E/R = 12/7 = 1.7A, so something is wrong with your math...
  3. pal114525
    Jul 3, 2015
    46
    Thanks for your valuable feedback.
    It is the circuit that is giving me this result. Don't know why?
    Thanks & Regards.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    And where is the circuit? post it?
    Answers to my questions?
  5. dl324
    Distinguished Member
    Mar 30, 2015
    3,397
    653
    The datasheet should also indicate the drop out voltage which will give you the minimum input voltage requirement.
    Are you taking meter resistance into consideration for your current measurement? If 6V was measured without an ammeter in circuit, I=6V/7ohms=857mA.
    1. What is the power source for the regulator (e.g. x volts @ y amps)?
    2. What is the regulator input voltage with your load?
    3. Is there a heatsink on the regulator?
